EFI vs Carburetor
   / EFI vs Carburetor #1
aspg4
texarkana, ar
Massey Fergerson 135, TYM 554
Any advantage of EFI vs Carburetor on zero turn mowers...
   / EFI vs Carburetor #2
carbs are on the way out you can even get a snowblower with EFI now ..
   / EFI vs Carburetor #3
Better fuel usage, more responsive throttle. Down side is if something goes wrong will need dealer support to diagnose for the most part.
   / EFI vs Carburetor #4
I think you are correct.... even though I prefer carbs on smaller equipment.... I can still clean & tweak a carb to make something run well without my dealer involvement....
   / EFI vs Carburetor #5
Not actually EFI but there are chainsaws with electronic carbs that also require it to be connected to a computer for diagnostics and to flash replacement parts into memory.
   / EFI vs Carburetor #6
I have EFI on my Deere X485 and it starts and runs awesome all the time. I will say, the downside is the cost of parts. I have not had to replace any parts for the EFI "knock knock", but looked at prices. Ouch.
   / EFI vs Carburetor #7
EFI doesn't get effected with crude build up like carbs do. They start quickly even after prolonged storage with fuel in the system. I think they also get better fuel economy.
   / EFI vs Carburetor #8
Not a zero turn, but a just bought a 2020 KTM motorcycle (dirt bike ) ...it is EFI....I was certainly hesitant. ..it's also oil injected... another new feature. ..so far it's been great. It has 2 separate and different maps in the computer for different riding situations..can't do that with a carb.
   / EFI vs Carburetor #9
My carb on my Toro z420 was trouble free for 13 years, then it started leaking fuel into the cylinder after shutdown, it's being replaced this spring.
I would expect EFI to be more reliable with current fuels and more fuel efficient.
   / EFI vs Carburetor #10
EFi I have seen on most small engines is very similar to the old throttle body EFI on cars/trucks in the 90's. Essentially you have an electric lower pressure electric fuel pump and some type of injector spraying it into the throat of what essentially is a carburetor.
Typically this give better throttle response and eliminate lag or dead spots on that some carbs will give but with a mower you are typically running at a constant throttle position. For a mower I would see EFI as a benefit of they generally have quick start ups and not having to worry about floats sticking.
Is EFI worth it on a mower. I'm not sure the costs is worth it. You are running at constant speed. Fuel efficiency I would think would be marginal between the two. If it was older carbs I would say go with the carb over EFI but most mowers now are set up so you can't adjust the fuel/air mixture on idle or main anymore on the carbs.
2000 Coachmen Mirada 340MB Class A Motorhome (A48082)
2000 Coachmen...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
2011 Chevrolet Impala 1FL Sedan (A48082)
2011 Chevrolet...
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
Pallet of Pulleys/Hooks/Come Along (A50860)
Pallet of...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
