effectiveness of pto irrigation pump
   / effectiveness of pto irrigation pump #1
nyiksca
harare
MF270
i would like to start a potato farming project 1.5h. i have a 45hp tractor and would like to use a pto pump for irrigation . my problem is the pto pump cost saving to run
   / effectiveness of pto irrigation pump #2
Welcome
What are you basing the cost savings on? Running your tractor Vs a stationary engine or electric motor.
Most tractors do not have any safety features built in to shut them down if they over heat, run low on oil, etc. Usually not a large concern but one to consider.
   / effectiveness of pto irrigation pump #3
Use a seperate pump and motor. It saves wear and tear on the tractor. What type of irrigation, sprinkler, flood makes a big difference. Are you pumping from lake or stream?
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
2023 Kubota KX71-3S Mini Excavator (A52377)
2023 Kubota...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
SCAN TO RECEIVE TEXT UPDATES (A52706)
SCAN TO RECEIVE...
378812 (A51573)
378812 (A51573)
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
