Edge material for Front end Loader Bucket
   / Edge material for Front end Loader Bucket #1
earthly2
What is the best way to use the bucket to move snow on a paved driveway without damging the asphalt??
Can I put a poly/plastic edge on the bucket to help prevent damage. I have looked at United States Plastic Corp. which sells 1/2 x 6" rectangular strips cut to proper lengths.
Would this be a good suggestion. How would I attacch to the bucket.
   / Edge material for Front end Loader Bucket #2
I would drill holes in the bucket edge like you would be installing a bolt-on cutting edge...which you are, sort of.
Don't be surprized if the plastic does not wear very long. You may also wish to contact May-Wes Manufacturing. web page They build all sorts of plastic parts for the ag industry including plastic cutting edge. It is pre-beveled and they will predrill holes for you. It isn't cheap but should work well.
   / Edge material for Front end Loader Bucket #3
I bought some 1/2" heater hose and have put a slit piece on the bottom of my back blade. I plan to put a piece along the bucket as well. Have tacked it here and there with Goop to hold it in place. Will let you know how it works.
Ralph
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2016 Freightliner Tandem Bucket Truck, VIN # 1FVHCYCYXGHHA5025 (A51572)
2016 Freightliner...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
