ECU on 2012 JD5065e ?
   / ECU on 2012 JD5065e ? #1
Rmiked
Fort Mill, SC
John Deere 5065e, 2013
I have a 2012 Tier 2 JD5065e tractor with the 9x3 TSS transmission, 4WD, no cab. Does my tractor have an ECU? If so, where is it located? I put my serial number (1PY5065ELCB009897) in the JD Power Assist parts catalog and it indicated an ECU only for the Power Reverser models. When it found my serial number under the ECU data it was blank. It also indicated No current software and No available software. I am just wanting to find out if my tractor depends on a computer to run and if so, where is it and how can you plug into it to check Codes etc. There is nothing near the fuse block that looks like an ECU. Thanks in advance.
Quick Attach Pallet Forks (A47384)
Quick Attach...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
John Deere 893 Corn Head (A50514)
John Deere 893...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
