Echo trimmer won't disengage
   / Echo trimmer won't disengage #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
I have a 11 yr old straight shaft echo trimmer. The head keeps spinning and won't disengage. Does it have some sort of clutch? Maybe it just needs to be greased? If grease, what kind should I use?
TIA!
J
   / Echo trimmer won't disengage #2
not sure on the model but it might be a busted clutch spring, would cause it to be engaged full time
Thanks, I took it apart a couple months ago and discovered the clutch bolts had simply come loose and were squeeking and jamming up in the housing :confused3:
Grabbed my torque gun and problem solved.
Thanks for responding!
Hose Reel (A53424)
Hose Reel (A53424)
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2003 500 BBL FRAC TANK (A53843)
2003 500 BBL FRAC...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
