Echo Pole Saw
   / Echo Pole Saw #1
BB_TX
Veteran Member
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
Was looking at the Echo Pole Chain saws at the local HD yesterday. $350. Does anyone have any experience with these? Echo seems to be a good brand in standard chain saws, string trimmers, and such, but I have never heard any comments on their pole saws. Search on here only turned up Stilh pole saws.
   / Echo Pole Saw #2
BB_TX
Check out the thread - Pole pruner: most useful acreage tool?
for feedback from blurrybill on the echo unit - sounds like a good tool similar to the stihl.
I tried the ryobi recirc saw type and returned it to HD as it was slow and had limited reach.
The chain saw type work well from the posts I have seen.
Carl
   / Echo Pole Saw #3
Here is the link to <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=off&Number=158731&page=&view=&sb=&o=&vc=1>Pole Pruner</A>
   / Echo Pole Saw #4
I used the Echo, and it was wonderful. The extension unit was a little heavy. I ended up buying a Tanaka <A target="_blank" HREF=http://www.tanaka.com>http://www.tanaka.com</A> that atttached to my string trimmer.
I really like it, and it isn't quite as heavy
It would fit many better trimmers, like husky, shindaiwa, etc.
   / Echo Pole Saw
Mike I think you meant <A target="_blank" HREF=http://www.tanaka-usa.com/>http://www.tanaka-usa.com/</A>
Is your string trimmer also a Tanaka? What was the cost of that unit? I have never seen any Tanaka products around here.
   / Echo Pole Saw #6
BB,
I can't say enough good things about my Echo pole pruner. Mine has the 12" bar, I believe. It's tough on the back when fully extended, but has tremendous utility. I recently trimmed some 12" dead lateral branches on some of our huge oaks. If you get one, pay close attention to instructions for how to avoid binding the chain -- if it's 15' up in the tree, it could be real problem! Good luck with your purchase; let me know if you need more information.
Bill
   / Echo Pole Saw
The HD guy said the basic pole was something like 7'-8', but that you could get a 3' extension. Do you have the extension and do you feel it is necessary? I just need to trim low hanging limbs to get my tractor ROPS under when mowing. Been doing it by holding my 18" chain saw up with one hand and cutting what I could reach. I know. Not very smart. /w3tcompact/icons/blush.gif But sometimes you do what you gotta do.
   / Echo Pole Saw #8
Oops! you're correct! That is the right link!
My trimmer is a Maruyama (doesn't EVERYONE have a Maruyama /w3tcompact/icons/grin.gif?)
I would not hesitate to buy a Tanaka. My brother in law sells them at his saw shop, and raves about them... He also sells Jonesred. He suggested that I get a more agressive chain, without antikickback; he felt that it wouldn't be a problem at the end of a pole.
One other consideration is conductivity. If you are going to be around Power lines GET A NONCONDUCTIVE SHAFT UNIT
(ECHO or STIHL)
I got mine from Grainger for $189.00 for the pole saw, they also make a 2' extension. With just the attachment, mine is 9' and does a great job clearing out low limbs.
I worried about the shaft flexing, compared to the Echo, but that is not a problem at all.
   / Echo Pole Saw #9
You can make a LOT of work with one of these, so I am going without the extension. I have around 30000 trees and an plenty busy, after I get caught up, I might get the extension.
I have a platform that i have for driving 8' fence posts that is 3' high, I stand on it, it is really sturdy, when I need extra height. I have also been on a ladder, and been OK, but not ideal.
I would rather have my lighter 9' unit than the heavy 11' echo that I borrowed
   / Echo Pole Saw #10
Check the website. Mine extends to about 15-16' WITHOUT an extension. I recall 3 or 4 models. I went with the longest bar, again, I think 12" and haven't regretted the purchase. Go longer if you can. It's amazing how those dead branches appear the more you trim. Mine was around $500 but it's a tremendous tool -- great way to find "friends" too, but family loves it like everyone else.
Bill
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
2011 Lexus RX SUV (A53117)
2011 Lexus RX SUV...
