fortyseven2n
Bronze Member
- Joined
- Mar 26, 2002
- Messages
- 70
- Location
- North Carolina
- Tractor
- 1947 Ford 2N , 1952 Ferguson TO-30 , 1953 John Deere 40 Standard, 2009 Kubota L3400 HST with Loader
I need some help on my Dad's PB-210E leaf blower.
It is a mid 1980's model and has always started easily and run well until this season.
He is using 50:1 mix per the book.
This year , starting was more difficult and it would run pretty good with some hesitation on acceleration from idle to full throttle but would die after running a while. Good running time varied a lot. I tried adjusting the high and low needles as I have in the past but had little luck.
Adjusting the low needle seemed to affect the idle rpm. Never had that happen before so I though that there may be a pinhole in the diaphragm or something like that.
I replaced the fuel filter, check valve , fuel lines and cleaned the carb and installed a carb kit.I ran the low and high needles all the way closed and backed out 2 turns. It started right up and with a little adjusting on the high needle ran full blast really smooth.
I cannot get it to idle at a constant rpm or accelerate smoothly.
When you let off the throttle, the engine tends to stay at a fairly high idle and the low mix seems to affect the idle.
There is also some gas in the air filter chamber around the carb. Maybe just excess fuel ?
I don't see how the carb could be leaking. The only place I could see is maybe where the carb mounts. There was not a gasket on it and none shown on the parts list.
Anyone have any ideas on adjust this thing so it runs smoothly again ?
Dad has had it so long and it has always done so well that I hate to give up on it.
Please help !
Thanks !!
Fortyseven2n
Please help !
Thanks !!
Fortyseven2n
