Echo HC-150 Trimmer
   / Echo HC-150 Trimmer #1
jmfox
Platinum Member
I have an Echo HC-150 Trimmer with a broken handle. Does any know if the handle assembly (#7 below), which includes the gear case, can be welded or brazed?
jmf
   / Echo HC-150 Trimmer #2
If its like my 150 I would say the only option is brazed, mine is cast. May be able to weld it with nickle rod too.
Would you say it is cast aluminum, zinc (pot metal) or iron?
jmf
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2019 JOHN DEERE 560M LOT IDENTIFIER 28 (A53084)
2019 JOHN DEERE...
2023 LandHonor RB-14-72W 72in Rock Bucket Skid Steer Attachment (A51691)
2023 LandHonor...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
