eating clutches,help!!
   / eating clutches,help!! #1
jimbgood
Farmville
Branson 3820, Huber maintainer
I have a Branson 3820 with 240 hours on it, I have put 4 clutch sets in it. The longest they will last is 20 hours. It is always the PTO clutch disc that goes out. Even pulled the PTO shaft and changed the two bearings on the shaft. I have spent thousands of dollars and a year and a half trying to fix this, I am at a lost ready to use it for a lawn decoration. Can anyone help?
   / eating clutches,help!! #2
I would hope it's still in warranty. 4 clutches in 240 hours is incredible (unless you're an incredibily bad operator!).
Are you the only operator? Do you ride the clutch (or even rest your foot on the pedal)?
I can't even guess what could cause this kind of premature wear, but I'd definitely be contacting the dealer and keep going up the food chain until you get satisfaction.
   / eating clutches,help!! #3
Roy has pretty much hit it. Only other thought I have is check the linkage adjustments, make sure there is a little free play when fully engaged so discs are not slipping slightly.
   / eating clutches,help!! #4
Ditto to Roy! I'd be standing on my dealer with both feet! That's just crazy!!!
~Scotty 370
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2012 BIG LOW BOY 130BBL VACUUM TRAILER (A53843)
2012 BIG LOW BOY...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
