Easy tiller and rotary plow transport
   / Easy tiller and rotary plow transport #1
Maine Hills
Bronze Member
Midcoast Maine
Kubota B2650 BCS 749 Kubota RTV X1120
For easy tiller and rotary plow transport with a BCS tractor simply reverse the handle bars so that the tiller or rotary plow is at other end from the handle bars and engine. Most of the weight of the tiller or rotary plow will be counterbalanced and only a moderate downward pressure on the handlebars will be needed to keep the tiller or rotary plow off the ground. Rotate the handle bars over the tiller or rotary plow when you arrive at the jobsite. I find this method of transport more convenient than installing the transport wheel.
   / Easy tiller and rotary plow transport #2
I should try this... it's a real nuisance to transport the tiller in the rear facing position, just heavy enough to be pretty tiring.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
