Easy storage & hookup to 3 pt
   / Easy storage & hookup to 3 pt #1
Chris in IN
East Central Indiana
John Deere 4400 hydro, loader, chipper, tiller, bush hog, blade, rake
Today I solved the problem of storing my 3 pt implements inside & keeping easy access for hookups & in the process made hooking up the implements much easier. Since I bought my compact tractor last November, it has been a chore to keep the implements out of the weather and keep the garage organized so I could hook them up. I solved the problem today by making platforms with casters to set each implement on. I can now store the implements lined up next to the wall. When I need to use one I can simply roll it over to the tractor. The casters make it easy to line up the pins for hookup.
The frames I made are simple rectangles made with 4 2" X 6"s with lapped corners, a swivle caster on each corner. For the grader blade I had to add an up right frame for the blade hitch to set on. I made these for my large PTO chipper, tiller, grader blade & box blade. For the bush hog I took a 2" X 8" cut 4" longer than the width of the deck, added 1 1/2" cleats to the ends & 2 swivel casters on each end. Just roll this under the hitch end of the bush hog and lower the mower on it. Hope this is helpful. Chris
   / Easy storage & hookup to 3 pt #2
Chris, that is exactly the plan I am hoping to put into use myself (I hate leaving anything out in the weather), but until I get rid of the gravel floor in my workshop, pushing those 2000 pound implments around on caster is really going to be tough!
   / Easy storage & hookup to 3 pt #3
Chris, that's fine idea. Of course, quality casters, and even lumber, are not cheap, but it's cheaper than things like the Freedom Hitch as long as you're always on a hard surface when you change implements.
Bird
I did neglect to say that a concrete floor is a must for moving the implements. As for the casters, I used 3" all steel that I bought from Tractor Supply for $8.00 each. They are rated at 300 lbs. each. The lumber I used was warped teated lumber that I got for 1/2 price from the lumber yard. I figured that using crooked lumber did not matter since weight of the implement would flatten the platform out & they did. If I had used regular retail lumber the total cost of the 4 platforms with all hardware would have been about $170.00. Chris
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
Walinga Agri-Vac (A50514)
Walinga Agri-Vac...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
