etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,018
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
There must be 51 different ways to make Hollandaise sauce. My wife really likes it and I tried several different ways to make a no fuss real Hollandaise sauce. About 40 years ago I figured it out. So simple I would make it camping. People were jealous. Eggs Benedict while camping. So here goes. You need 4 egg yolks, 1 cube of cold butter, lemon juice to taste (I like a lot, about a whole lemon) and cayenne pepper to taste (I like a lot of that too, my wife less so). So first cut the butter into about 16 pieces. Then whisk the lemon juice into the yolks in a pot. Put the pot over low heat and throw a piece or two of butter in the pot. Keep whisking until the butter melts and is fully incorporated, then add a piece or two more and repeat until all the butter is whisked in. You will now have a nice thick sauce. If the sauce is thin then gently heat while constantly whisking and it will thicken up. Remove from the heat when it is slightly thinner than you want as it will thicken up after sitting a couple minutes away from the heat. Serve with cayenne but add a little before serving. The trick is to keep the heat just sufficient to melt the cold butter. The cold butter helps to keep the yolks from cooking too much or too fast. Make sure to get into the corners of the pot otherwise the egg yolks will get too hot there and cook too much. It is best to keep the heat too low than too high. When cooking over a fire I hold the pot above the fire where I think it is cool enough. I haven't had a broken Hollandaise sauce in well over 35 years. If the sauce does break then remove from the heat and whisk in 1 more egg yolk just a bit at a time. Don't try to re-heat as this will probably break the sauce again. Just enjoy a little less warm.
Eric
Eric
