Easy Hitch
   / Easy Hitch #1
Natureboy
Upstate NY
JD X728
I was thinking about getting one of the Easy Hitch systems from Pats, then noticed that it requires 4" of straight arm. I assume that means the straight part of the lower links that includes the ball where the pins attach. I measured my CK20 HST arms, and they are only 3" of straight material.
During the winter I have my snowblower on constantly, but during the warm months I am looking for an easier way to go between brush hog-carry all - rake. Anyone out there had experience with the Speeco easy hitch systems that attach to the 2 bottom links, sold at TSC? Is the quality the same as Pats, and can you get away with a 3" straight arm?
   / Easy Hitch #3
I have a Pat's EZ Change on my CK20H and it works fine. I haven't taken it off since I put it on about 3 years ago.
   / Easy Hitch #4
Ditto Noland.
The only problem I had with fit was my snow blower. The blower lower points were designed to have the hitch lower arms go inside a channel with the pins inserted thru the ball ends. A real pita, so I had to some cutting with a sawsall and got longer bolted pins from TSC.
The one thing I suggest you do is get a longer top link at TSC, this makes up for the extra 3" and will help you level out your equipment better
2016 Ford Explorer...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
36" Smooth Excavator Bucket (A50774)
36" Smooth...
CAT D16 LGB (A50322)
