Tires Easiest Way Widen Track CK30 AG Tires?
   / Easiest Way Widen Track CK30 AG Tires? #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
So, for those who have done it, do you take the whole wheel/tire off, or do you just jack it up and take the external tire/wheel off and switch it that way?
Mike
   / Easiest Way Widen Track CK30 AG Tires? #2
Going from memory, it will depend on which way the inside rim is mounted now. But probably from the stand point of lining up the bolt holes it will probably be easier to remove the whole rim. Do you have a torque wrench to re tighten the bolts once you are done or is it the turn it til you have no more strength method like me? (probably have the torque you need as in my case)
Steve
thanks, well torque wrench probably doesn't go that high! but it's not exactly high speed operation, so just real hard would be good i think
mike
   / Easiest Way Widen Track CK30 AG Tires? #4
Take it off and do it that way it is much easier.
BTI
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
Chevy Car (RUNS)(TITLE) (A50774)
Chevy Car...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
