Easiest FEL Attachment changes for my CK2510Hst
   / Easiest FEL Attachment changes for my CK2510Hst #1
GJHLAW
Hey Gang,
New to all this, I recently purchased a CK2510Hst, with the KL2510 loader. Looking to get some pallet forks, maybe a plow blade, but do not want to be bothered with Pin attachment every time i switch. Whats the consensus opinion on the best set up / brand / equipment for an aftermarket QA solution ? ( Will be lifting my sleds into racks, about 500-600lbs, not looking to use "pin on" forks).
GJHLAW
   / Easiest FEL Attachment changes for my CK2510Hst #2
Doesn't the CK already come with standard SSQA on the loader?
If not, an after market conversion to SSQA is the way to go, then you can get any brand attachment except for John Deere's.
   / Easiest FEL Attachment changes for my CK2510Hst #3
The 2510 comes with pin on standard, the 3510 and 4010 have the ssqa.
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A50322)
2009 Yale...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
