Easiest (/cheapest?) way to add 3PH tilt & grapple bucket functionality?
   / Easiest (/cheapest?) way to add 3PH tilt & grapple bucket functionality? #1
Colgate2004
Bronze Member
Augusta, Maine
None (yet!)
Hi all,
I'm about to buy my first non-lawn&garden tractor, a JD 3025E. I've got the tractor nailed down, now I'm in the process of configuring the build.
I want the ability for a tilt setup on my 3PH (not a full "top & tilt" because I don't really anticipate needing the "top"-ing function, but I do want to be able to hydraulically tilt 3PH implements), and I also would like to give myself the ability to have a 3rd-function (is that the proper term?) implement on the FEL, like a grapple bucket.
Problem is, I have limited funds to accomplish this (the tractor selection itself is a reflection of this... if I had more money to play with I'd get a more powerful machine, but the 25 horsies under the hood of the 3025E will have to suffice for me).
The dealer quoted me $1,100 for a set of rear remotes/SCV, installed.
Is there a less expensive method?
(I am hoping that I can get away with adding only one set of remotes, in the front or rear, and running a long set of hoses from that set up to the front for the grapple, since I certainly won't need to be using something on the front AND the back simultaneously.)
Any and all thoughts and advice appreciated.
P.S.- I've read some about some folks installing diverters to use a 3rd function up front, momentarily disabling one of the other bucket functions... do I understand that correctly? That seems like it could be a great option, if it is inexpensive, and if I'm not misunderstanding something...
   / Easiest (/cheapest?) way to add 3PH tilt & grapple bucket functionality? #2
If you are purchasing this new...
I would think long and hard about your long term use. I understand your desire to save money. And I agree, however, you will use this tractor for 10-20yrs (in all likelihood) and you will kick yourself each and every time, you are unable to use your hydraulics in a useful manner.
This is my opinion, but, I would get EXACTLY what you envision needing 5 years from now, rather than what you think you can get away with currently. That extra $10/mo payment will be money well spent, when you are using your grapple, tilting/angling your blades, etc etc etc.
Money is ALWAYS an issue, there is no doubt. But to make a big purchase through a dealer, then cut corners on what will make the machine enjoyable, is not where I would recommend going. Rather I would recommend buying a good used machine which has everything you could possibly need on it.
My opinion...
I purchased a used machine, off lease, from a dealer. I had another set of hydraulics added for a grapple. It has 2 sets on the back. I REALLY wish I had told them to add at least another set on the back. I can make due for my needs, but it is always a choice of what is more necessary. And, in a few weeks, Brian at FitRite hydraulics, will be making it even more difficult, by sending me a top/side link system. There goes my 2 connections....
   / Easiest (/cheapest?) way to add 3PH tilt & grapple bucket functionality? #3
Wrong, you don't anticipate needing the "top"-ing function because you have never had it.
I speak from experience, once I got a hydraulic toplink, I said I would never own a tractor without one.
I don't recall anybody posting that they don't like, or don't use their hydraulic toplink, it is just the opposite, everybody now thinks it is a necessity.
Case International 3450 Round Baler (A51573)
Case International...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
PumpJack Brand Pump Jack (A53472)
PumpJack Brand...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
