Earthforce EF3 B200 - Information Request
   / Earthforce EF3 B200 - Information Request #1
Jimz2
Wausaukee, WI
Earthforce EF3 TLB
Hello all! My name is Jim. I recently purchased a1999 Earthforce EF3 machine with 1200 hrs. The seller made me aware that the machine's hydro drive was weak before I purchased it. All the same problems as others who own these type machines. Slows down, weak power as it heats up. I am in the process of removing the main Bondial Pavesi pump and am going to have it either rebuilt or purchase a rebuilt one, as soon as I can get it out of the machine. The 2 main mounting bolts are very inaccessable and I am hoping that I can get to them with a 22mm crowsfoot wrench that I ordered from craftsman. My question today is: from reading others posts on here, (I have been reading 2 other members posts, gjb012 and SSdoxie, and both of you are very knowledgeable on these machines). I read on your posts about hooking an additional oil cooler inline for better cooling of the hydro fluid. I have located the 2 lines out of the existing cooler under the seat and it has 2 lines, one about 1 1/8 going back to reservoir, and the other about 5/8" going up towards the front loader. They are both coming out of the same block on the cooler. I would like to know if anyone has installed any auxilliary coolers on their machines and where would I tap in to the lines?? Would it be just a matter of cutting the line and attaching the cooler hoses with barbed fittings and hose clamps? 1 line to aux cooler intake and 1 line back to cut hose from aux cooler outflow? Although I think that the logical choice of hose to tap into is the larger hose going back to the reservoir, I am scared to tap into the larger of the 2 lines, the one that goes back to reservoir, as I fear the pressure from reducing down from the 1 1/8 hose to the 11/16 aux cooler size hose may be too much, and also, I worry about there not being enough flow volume from this smaller sized hose causing a restriction of flow back to the reservoir:confused:. Any guidance anyone can give me on this would truly be much appreciated. Jim
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
2015 Nissan Rogue SV SUV (A48082)
2015 Nissan Rogue...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
