Earth Tools now offers tracks??
   / Earth Tools now offers tracks?? #1
CodeMonkey
Orygun
Grillo 107, BCS 730
:eek:
Earth Tools
I have read threads about tracks offered from Canada and some comments that they weren't good for the tractor?
I was just looking at what accessories and implements I was going to order and I was thinking about getting some larger wheels and noticed these new tracks from Italy.
I work my tractor (Grillo 110) mostly in the land clearing role using my Berta 26" flail mower, and I do this in my forest, which is rough ground, sometimes large depressions and ruts and mounds and such left by heavy equipment when I had my trees thinned. I also sometimes hit small logs and other obstacles that are hidden by the vegetation which is quite thick. This summer about 75% of the struggle dealing with brush was dealing with the rough terrain where I couldn't see the holes and such and I would get both the mower and the tractor stuck in them - and that is with dry ground (very dry this last summer).
I also have a gully, about 50 feet deep with a part time wash at the bottom, that separates about 10 acres from the rest of my property where I would like to take the flail over and clear some trails (the brush isn't as thick, but it does grow up and the trails need to be mowed). There is a path that is walkable down into and across the gully, but I don't even want to tray to get down and back up it with the tractor pushing the mower, for fear I would never get it out of the bottom of the gully without a winch.
I was thinking that tracks would be great, but they weren't available - now it seems they are, and that they would be ideal for what I do.
I would want the rubber tracks because although the steel would be better in the woods, I do have to go across my paved driveway and I use the flail to mow my lawn too.
Thoughts?
Anybody have any experience with these particular tracks?
Found a vid.
Not how I wanted to see it used - I want to see the tracks in the mud and going through holes and over things.
Better
   / Earth Tools now offers tracks?? #5
I think they'll be very effective for traction and stability. The old one you are talking about were not well thought out and were kept from spinning with a short length of chain. They caused a lot of stress on the transmission housing and led to premature failure of said housing. Joel tells me these have a better designed system for mounting. The biggest downfall is of course the price. $1100 for the hi-speed units, 1300 for the rubber lo-speed units, and $1400 for the steel lo-speed units.
I have a set of the hi-speed tracks on order. I'll give you a review after I try them out with a BCS 735 and Ravenna trailer.
Compared to the amount of effort I put in trying to keep my tractor from getting stuck, and then getting it unstuck, the cost is insignificant. I can always compare it to the cost of a heart attack or heat stroke. :D
Apparently this Agrizeta makes tracks for a number of machines - not just two wheel tractors:
https://www.youtube.com/channel/UCFr8muVqbLyhlNMWGdW7lCQ
I am trying to figure out which rubber tracks are which - I think I want the ones with the larger drive wheel. In my experience and observation, if you want a track to climb over something or up out of a hole, you want a decent upward incline on the track. The other two tracks are flat and then a short but backwards angle up over the forward bogie.
I am going to bet the one with the large drive wheel is the hi-speed unit - large wheel means it covers more ground per RPM.
Yup - looking at their website, the larger drive wheel unit has no speed reduction - and I am betting, depending on the wheel you replace, it is probably caster than most stock wheels.
Which is fine for me, when I am using my flail in heavy brush, I run in first gear.
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
UNUSED CFG INDUSTRIAL MX12RX EXCAVATOR (A51247)
UNUSED CFG...
TEYME 2000 E0L0 GTE10 LOT NUMBER 212 (A53084)
TEYME 2000 E0L0...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
