E120 wont run or start
   / E120 wont run or start #1
kengolding
Ford 9n
It will start with starting fluid, no problems.
New mower 2.5 hours
I removed the small plastic incline fuel filter and nothing drips out.
The tank is full.
Is there another filter?
   / E120 wont run or start #2
New mower 2.5 hours
The tank is full.
Welcome back to TBN
I would not work on it, it's band new, factory warranty, take it to the dealer who sold it to you. If they discover that you have worked on it, your warranty will be void.
Richard
   / E120 wont run or start #3
:welcome: to TBN
Will it stay running after starting ??
I removed the fuel filter and nothing drips out.
Is this with the key turned on and cranking the engine?
Sounds like time to take it back to the dealer with being new and only 2.5 hours.
Are you long on experience with gas engines? or new to them?
Is this a California model?
Can't be too hard, just not getting fuel, otherwise runs fine. Even the manual says to change the fuel filter
   / E120 wont run or start #5
Your response didn't answer many questions... what does "otherwise runs fine" mean?
I meant if it had fuel it starts just fine. If I spray starter fluid it runs until I quit.
I fixed it. I put a small plastic hose on the fuel line and sucked fuel up until it was coming out. I then put the filter back on and it is working just fine. Must have had an airlock
Yes with the key on and cranking nothing was coming out. Until I sucked all the air out. Running just fine now. I have lots of experience with gas engines, just did not know if there was another fuel filter I was missing. not sure what caused the air to be in the line
   / E120 wont run or start #8
Asked if in CA, as there is another canister at the fuel tank.. but didn't hear back.. glad you have it fixed..
Sorry, I saw your post about ca but had it working. I am in FL but it does have the cannister at the back
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
Wheels and Tires for Four-Wheeler (A51573)
Wheels and Tires...
Pop up camper (A51694)
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
