E MAX PTO shaft MMM.
   / E MAX PTO shaft MMM. #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
What the flying frog is the easiest way to reinstall a PTO shaft when you remove it to service the deck? How are you people doing it? I'm struggling every time I do one. Seems like there is just not enough room to get at it.:confused3:
   / E MAX PTO shaft MMM. #2
Jabonee, it is a real pain sometimes. I have a Max 28 and best way I have found is to make sure the deck is on a surface where the blades can rotate easily. I lay down behind the tractor and rotate the shaft a little at a time until the splines mesh and slide onto the PTO shaft. Obviously you have to pull back on the spring loaded collar as your doing this. I actually have a harder time hooking up the brush hog to the back PTO! Hope this is what you were referring to and my explanation was helpful. Good luck!
Dave
Dave
Thanks Dave. I've tried it from the back of the tractor but I always have the front up in the air. I will try it with all wheels down,mower down and see what happens.:thumbsup:
   / E MAX PTO shaft MMM. #4
Dave is right on. It is a bit of a pain. I do it from the back of the tractor. Wheels and mower are down. I'm right-handed, so I lay on my right shoulder or back and can get it most of the time one-handed. Plays **** on my rotator cuff that way. Otherwise I'm on my belly doing it two-handed. Much easier on the flat concrete floor so the blades/shaft can be rotated slightly till the splines line up. Doing it on the grass makes it easier to drive on/off the deck, but aligning the splines is a different story.
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
