E break noise I think?
   / E break noise I think? #1
Dan Lamb
MC Cloud Ca
Branson 2400h TLB/ cab
Hey guys ,
I am hearing a noise coming from my L rear tire wheel area , when I first got my tractor I left the E break on more than I would admit but it the noise is in sync with wheel rotation and I am working in a very dusty environment. Should I take wheel off for inspection and cleaning , any advise would be appreciated, Dan
   / E break noise I think? #2
You can try blowing the dust our of the area but dust may have gotten into the brake area and it's possible you'll have to disassemble the brake to quiet the noise. Of course you can check your brake for wear at that time. (Lacking an indicator I find it easy to forget to release the parking brake, too.)
   / E break noise I think? #3
Does the 00 series have a dry brake or wet brake setup?
Ptsg, I believe that they are wet break system but I will look that up in my book when I get home , I know this seems odd but it quit making that noise today when I was working my tractor ,odd deal ????? Thanks guys for responding, Dan
   / E break noise I think? #5
I wonder if it was just a stone caught up in the hub area?
Hey guys,
That darn squeek is back , it is a wet break system , I looked in my book and it is very vague on explaining, can anyone with any experience with this please explain what I'm iooking for , thanks guys any help would be greatly appreciated, Dan
   / E break noise I think? #7
The reason I asked for what type of brake it had, is because the wet brakes don't usually make any noise, unless something bad is happening inside. Dry brakes, however, could possibly be dragging and make some noise, but then again, it's not the case.
Have you tried to lift the tractor with a jack and move the wheel around by hand to see if you spot something obvious?
   / E break noise I think? #8
Does the squeak change when you apply the brake? Have you checked that the lug nuts are tight?
   / E break noise I think? #9
Go tighten all of your lug nuts. Check for "egged out" holes on the wheel hub. They already may be damaged. There is nothing wrong with your BRAKES. They are not BREAKS. If you have multi piece wheels check all of the bolts and nuts that hold them together as well.
Thanks guys,
Now I know what to look for ,I am 88 miles away from my job but will bri
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2002 Ford Ranger XL (A50323)
2002 Ford Ranger...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
Show Livestock Double Blower Stand and Fan Stand (A50515)
Show Livestock...
