dynahoe parts?
   / dynahoe parts? #1
jessejames88
i'm looking for a few parts for my 190 2wd dynahoe, wheel cylinder or rebuild kit tranny rear seal the seal behind the parking brake and a dipper cylinder or packing kit any idea's where to find these things???
   / dynahoe parts? #2
Any hydraulic shop should have a hyd cyl packing kit.
The trans. seal should have a number that will interchange at most well stocked parts store.
Take the wheel cyl. to a HD truck place. If it doesn't have any readable numbers on it, ask to see the picture book. If they don't have a picture book, go somewhere else. :D
   / dynahoe parts? #3
The master cyl (brake) is a Wagner unit - take yours out, take it to NAPA, and they'll order you one up.
I just picked up a a bunch of parts via Tracey Roads in Syracuse NY, but they're just ordering from MinnPar out in Minnesota (MinnPar only sells to dealers, not direct). I got a few new pins and bushings, as well as the main lift cyl rebuild kit (not cheap).
where are you located? I have an extra hoe (D190, 2wd like yours) that once I rebuild the blower will be up and running again, in case you want another one:). It's in northern VT, near Burlington.
   / dynahoe parts?
i'm in narrowsburg ny thanks for the help guys
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
