Dyna 4 Tranny Not Working Properly
   / Dyna 4 Tranny Not Working Properly #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
I have a MF5465 with Dyna 4. So far I have had codes 1 & 12 on the range indicator lights and another code on the dash gear selection lights. As of now, the tractor will not reverse at all. Yesterday the I could not select gears but I could change the range. I have had the reverser in neutral and an alarm sounded when I applied the parking brake as if the reverser was in F or R. My neighbor also has a 5465. It has the notorious code 23, bottom of clutch switch. Sometimes the reverser on his doesn't work. Usually fixable by shutting down and restarting. But I have even seen it go forward when put in reverse. Seems like MF would have a recall for the BOC switch as many problems as I hear about. But what is the deal with the Dyna 4, electrical issues, solenoids, :confused:
It's been one of those days where nothing works like it's suppose to. Oh, thank goodness. I see it is 5 o'clock.....somewhere. :drink:
   / Dyna 4 Tranny Not Working Properly #2
Have you got the serial number? There were a few that the power shuttle/shift box on the left of the steering wheel went bad.
   / Dyna 4 Tranny Not Working Properly #3
I haven't had your problems, but it is fairly new. How many hours has yours done, and what year?
It's 2008 with 9xx hours. I went through looking for loose wires or connections. Really didn't see any but wiggled wires and connections making sure all were connected well. Not sure if that fixed it or just being shut down for a few days but it all works now with no codes. Serial number T007087
   / Dyna 4 Tranny Not Working Properly #5
Both of our MF 6160's were recalled and had fwd/rev levers updated for this problem on older dynashift . The 3120 had to have the dynashift lever it's self changed . The 8130's , 6180 and 6190 were fine ?
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
11' CONTAINER (A51248)
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
