Dye in engine oil
   / Dye in engine oil #1
317140
Bronze Member
North Carolina
John Deere 3520
I was checking the engine oil in my 140 today before using it to get up leaves. Under the shed when I checked the oil it appeared to be low. I topped it off and moved it outside to hook up the leaf catcher. Just as an afterthought I checked the oil again and found that I had overfilled by a substantial amount. So I had to drain out the overfill. I would like to say that this is the first time that this has happened, but it's not. new oil and bad light make for a aggravating situation. I have a 317 mower and a 3520 compact tractor and the oil is hard to see on the dipstick on these also. After they run awhile and the oil turns a little black it's easy to see. I know our eyes get weaker as we get older But I had the idea that a little dye in the engine oil would make it easier to see. Am I just crazy or am I overthinking this. These ideas usually come to me when I least expect it.
   / Dye in engine oil #2
JD sells a dye (MT3668, $3.69) to use in the Hy-Guard fluids for just that purpose. Not sure if they reccomend it for engine oil or not, but seems like it might work.
   / Dye in engine oil #3
I've drilled a small hole in a Toyota dipstick because the oil level was hard to see. With the hole, at the full mark, it is immediately recognizable as being full.
   / Dye in engine oil #4
I know the problem..
Your oils not dirty enough:D
Just kiddin
Drillin a hole like mentioned in earlier post helps.
   / Dye in engine oil #5
I look at it at an angle and it is easier to see that way.
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
UNUSED JMR 40" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED JMR 40" HYD...
