DX25E Parking Brake
   / DX25E Parking Brake #1
barbindr
Cleveland, TN
Case DX25E
Good Afternoon everyone. When I set my parking break the tractor still wants to creep even on a small incline. Is there an adjustment for this problem. TX in advance for your help
   / DX25E Parking Brake #2
Are you in neutral? Do the regular brakes work? All the parking brake does is hold the normal brake set when you release the pedal. If the ratchet is worn and not holding, that could be the reason. You should be able to hold the brake pedal down and then press the parking brake to hold. If you are not in neutral and the HST is creeping, that's a pedal adjustment issue rather than a brake issue.
TX Jim for your reply. I'll check the pedal adj.
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
