dx 33 quick attach forks
   / dx 33 quick attach forks #1
quickwrench
Hello, I have just purchased a case dx33 with loaded and cab,and the first thing I want to do, after mowing alot of snowbanks is to be able to move pallets.How much weight can the bucket withstand with the bolt on forks,
and can a quick attach pallet fork go on where the bucket now mounts?
   / dx 33 quick attach forks #2
Looks to me that your loader will lift about 1300# at the lift pins. So I would assume with the bucket forks you could lift about 1000#. If your loader has the ss quick-tach to remove the bucket any quick-tach pallet forks would work. Depending on how often you are moving stuff with the forks I would get a quick-tach set. You will find many uses for them.
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
378714 (A51573)
378714 (A51573)
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
