Dust caps for hydralic lines
   / Dust caps for hydralic lines #1
jstern
East Aurora,NY
New Holland T1110
Does anyone know where I can puchase 3/8 dust caps for the quick disconects on my 210TL New Holland FEL. My dealer wants $65 for the color coded set. This is a brand new loader and they are telling me that they are no lnger included. **** I could machine them out of Titanium for less, but unfortunatly I can't blowmold plastic.:mad:
   / Dust caps for hydralic lines #2
My local NAPA store said they could get them. I just say a set of 12 color coded ones on eBay for $29.99. Look around, I expect you can find them cheaper.
   / Dust caps for hydralic lines #3
Try TSC. I have purchased 1/2" black and blue dust caps and plugs made by Pioneer for $3.99 a set. Not sure if they stock 3/8" but it's worth a try. They are not an online sales product but they will at the store order them in for you.
   / Dust caps for hydralic lines #4
Maybe NAPA or an autoparts store that builds hoses.
   / Dust caps for hydralic lines #5
I've ordered fittings from (this) outfit a few times. I've seen dust caps out there as well. $20 minimum order if I remember right.
   / Dust caps for hydralic lines #6
I just purchased a T1520 with a 110TL loader. All dust caps were included. When you spend that much money on a tractor from a world class company there is a reason. Sounds like the dealer is not being fair.
   / Dust caps for hydralic lines #7
Mine came with dust caps but all black. Bobcat uses color coded nylon zip ties behind each coupler set. That way if you tear dust cap off you just buy another standard black one.
   / Dust caps for hydralic lines #8
You might check your nearest Northern Tool & Equip store.
EDIT: I have found that my "female end" dust caps do not stay covered. When there is a bit of oil in the plug (and there always is) the covers pop right out. If you want a permanent solution, go to Surplus Center or some other cheap source and buy male 3/8" pioneer connectors. Put a plug in them and then just plug them in instead of the plastic covers. You can paint the connectors or put colored ID tape around the lines to make matching easy also.
   / Dust caps for hydralic lines #9
Check out
dixcounthydraulichose.com
I found them here while looking for qd's this morning, and the caps are under $2.
ISO 7241-B Quick Disconnect Nipple
   / Dust caps for hydralic lines #10
Smart Farmer has them. 3/8 or 1/2 a pack of 12 in six colors for $30.
Unused Delta Crash...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
Polaris Side by Side (A50324)
Polaris Side by...
