Dump trailer
   / Dump trailer #1
HomeBrew2
Banned
Dunlap, CA
Kubota BX23
Finally picked it up today.
Seems to do what I hoped for ... so far.
7000# GVWR
Elec/hyd motor/pump.
   / Dump trailer
The load is 10 Baby scoops of crushed granite.
I'm guessing 100#/cu.ft @ 5 cu.ft per scoop = 5000# load.
Springs were getting flat but not yet flat. Cool.
Cheers!
   / Dump trailer #3
Can you haul your BX in there too?
   / Dump trailer
Yes, I sure can ... maybe not with the FEL and BH or another implement, but I only expect to have to trailer it if there's a major breakdown that's covered under warranty or that I can't handle.
Thanks for the reply and, cheers!
   / Dump trailer
Finally got a chance to get some work done before dark.
Here's a pic of the overall trailer from the side
   / Dump trailer
Now one showing the nice 16 ga tool box housing the elec/hyd system
   / Dump trailer
I realized an interesting feature of my new dump trailer ...
I checked the battery voltage before moving 3 more loads of gravel tonight and it was at 12.2+/- volts. As some folks say, being from the RV world, I really don't like my RV/marine batteries to drop below 12.3+/- so I simply got my trusty Honda 2000i genny and a battery charger and put them to work. I never would have guessed that I'd have enough room on the tongue for the genny nor in the tool box for a charger. COOL!
Cheers!
   / Dump trailer #8
I HAVE A 6' X 12' 12,000LBS DUMP AND LOVE IT. I MADE RAMPS FOR IT AND CAN HAUL MY TERRAMITE FEL/BH ON IT OR MY YM2000 "I HAVE TO REMOVE THE TAIL GATE WHEN HAULING THE CUTTER". YOU WILL LEARN HOW MANY DUMPS PER CHARGE. I RUN A WIRE FROM MY TRUCK BATTERY TO THE HITCH AND INSTALLED A PLUG TO CONNECT THE TRAILER BATTERY SO IT WILL CHARGE WHILE DRIVING. "HAVE TO UNPLUG BEFORE DUMPING SO I WON'T BURN UP THE CHARGE WIRE". I'M SURE YOU WILL LOVE IT!
   / Dump trailer #9
My son has a dump trailor. He had the voltage drop issue. He took welder cable and a welder connector set to connect his trailer to his truck. He leaves the truck running and can use the dump as long as he wants. The sad thing is that he probably has as much $ in it as you do in your gen set.
   / Dump trailer #10
You might be surprized at how much that generator costs. It is the cat's meow though.
378807 (A51572)
378807 (A51572)
43029 (A51691)
43029 (A51691)
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
