Dump Trailer Plans
   / Dump Trailer Plans #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Anyone have dump trailer plans for a 10-12 foot model ? I have been collecting parts for a build. I have ten pieces of ten foot five inch channel ( nice hd pieces ) and two Dexter 8k brake axels with springs and eight bolt hubs. A local custom metal shop will bend up 12' 1/8" sheet metal ( two pieces 4x12 metal and bending ) for a little less than seven hundred. ( $550. for 10' ) Have a free cylinder and mechanism from a five yard box. I don't know if the cylinder will work with an electric battery style pump due to the volume of oil needed. If I found a good example I probably could measure a factory built unit.
   / Dump Trailer Plans #2
the size of the cylinder will not really matter. only thing if its to big it will be very slow. But even the manufactured units are not quick with a 12v pump. those pumps have good pressure just not volume, it takes more power to have more volume. If you get this project done and want it faster you may want to use a gas powered pump, which in nice in one way you don't need to have a battery on the unit.
sounds like a fun project, I am lucky and have a brother with a dump trailer I can use at will
2019 Allmand Light tower (A49461)
2019 Allmand Light...
International 4700 Vibra Tiller (A51039)
International 4700...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2008 Ford F450 (A49461)
2008 Ford F450...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
