Dump trailer mod
   / Dump trailer mod #1
Mighty Dodge
The Hereford Zone, MD
JD 4200
I have a 6x12 dump trailer electric/hydraulic single cylinder lift. I usually don't leave a battery in it, can't see the point of having a good battery just sitting most of the time. When I do use it on the road I put a battery in of course. This weekend I used it with my compact to haul 3 cords of wood and I got to thinking what would be involved in converting it to use both the on board hydraulic system and adding a quick connect to hook it to the tractor as well. Is this possible?
Thanx
John
   / Dump trailer mod #2
I see why it wouldn't work. Put a valve in to shut off the unit on the trailer and tee in for the tractor hookup. When using the tractor the valve well keep psi from the power unit and when on the power unit psi would be on the couplers.
   / Dump trailer mod #3
You will need to flush out the trailer's hydraulic system before anything is done, I would guess. You don't want to mix different fluids in your tractor. My dump trailer has transmission fluid, (atf), in it for oil which would need to be flushed. I wonder what the electric motor produces in terms of fluid psi verses the tractor? What you guys have is a good idea!
   / Dump trailer mod
Thanx for all the responses. I'll put this on my to-do list which means I'll probably never get a round tuit but ya never know.
   / Dump trailer mod #5
I would also consider the fluid capacity of the tractor. The dump trailer probably has a 4 or 5 in bore cylinder and can use a lot of fluid when fully extended.
   / Dump trailer mod #6
If you don't want to keep a battery in it, why not just rune the electric lift pump from the towing vehicle electrical system?
Easier that trying to tie into the hydraulics.
Ned - TC29DA
Kent WA
   / Dump trailer mod #7
Kent...I think you would have to run wiring from the vehicle's battery to the trailer. I don't think the pig tail going into the trailer lights would work. Have you done anything like this? I think that would be the best way to go.
   / Dump trailer mod #8
Run some heavy cables back from the battery to rear of the tractor and use some Anderson Powerpoles or equivilant to make the connection. You could also put a pigtail on your battery with a Powerpole so when you want to use the battery you can just plug it in with no tools required. This also makes it easy to remove the battery when the trailer will not be used for extended periods. Iam looking at dping this with my trailers, two of which each have a battery. I could get down to one battery that I could swap between the trailers as needed.
Anderson Powerpoles:
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
Quick Attach Pallet Forks (A47384)
Quick Attach...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
2014 CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
