CurlyDave
Elite Member
Yesterday, I went to the dump and dumped a load of debris with my dump trailer.
When I went to lower the bed, I could not get it down. It is single acting cylinder type, with a battery powered hydraulic pump to raise and a solenoid valve to allow it to lower under its own weight.
I managed to get it out of the active dumping area at the landfill and over to the side of what passes for a road. I didn't want to drive it too far because I saw a danger of tipping over.
Anyway, I ended up loosening a fitting on the hydraulic hose, which allowed the hydraulic oil in the piston to leak out onto the ground (who, me, polluting the dump?). This lowered the bed and I was able to get it home safely.
The original instructions are long gone, and I am wondering what type of hydraulic fluid to put back in it.
I am not sure it makes a whole lot of difference, because it seems like a light duty application to me, but I would hate to ruin the pump by putting in too low a grade.
I only need 2-3 gallons, so price is not an issue.
Right now, I am thinking of just getting a few gallons of WalMart's tractor fluid and using that. Anyone have a better suggestion?
