Dump Trailer Cylinder Stroke Length
   / Dump Trailer Cylinder Stroke Length #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
What length stroke does a scissor lift dump cylinder need for a small dump trailer say 5'x7'?
   / Dump Trailer Cylinder Stroke Length #2
We'll need the distance to the pivot points to calculate.
   / Dump Trailer Cylinder Stroke Length #3
depends on how you design it, some dumps use a muli stage cylinder that has no loss in mechanical disadvantage, and then some use a short stroke cylinder and a "hoist" that extends the perceived length of the cylinder,
I would suggest to down load some broachers or info pages on hoists, and "copy" there design and use there length recommendations,
or if you plan on making your own, (I would suggest to make a template out of card board, or 1/4 ply, and then lay the cylinder on the template and work it seeing nothing bines and that is long enough or the mechanical advantages are close to what you think they should be, usually the greatest disadvantage is just as it starts to lift,
2002 CRESCENT 102" X 53' STEP DECK TRAILER (A51247)
2002 CRESCENT 102"...
CHEVROLET CREW CAB TRUCK (A51247)
CHEVROLET CREW CAB...
UNUSED AGT LRT23 STAND ON SKID STEER (A51247)
UNUSED AGT LRT23...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
Pallet Fees (A50775)
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
