dump trailer build round 2!
   / dump trailer build round 2! #1
davedj1
Veteran Member
Jackson, NY
Kubota L2501
Ok, some of you know my last go-round with the dump trailer idea.
Had a brain fart yesterday afternoon and called a budy up north that owns a campground. He always has one or two old trailers that people give up on. He said "sure, I got a couple", so off I went this morning. Ended up with a 30' tandem frame not including the tongue for 300 buckeroo's.
The ride home (1 1/2 hrs) was brutal, the thing shook me nearly to death!
The first thing I did when I got home was to measure out what I wanted to keep, got the jackstands and cordless sawsall out and went to town! The frame is 2" x 5" x 1/8" box tube. Axles both have brakes. I have no clue what the axles are rated for but there is an aluminum tag I am going to try and decode. I'm guessing they are 3500# axles.
One thing I have noticed on storebought trailers is their welds don't seem to look worth a darn. I have a carry-on (tractor supply) and the welds on that just plain suck!
So now I have a good start on it, maybe if I can sneak (wife hates me spending money) some steel home tomorrow I can start the dump box.
OK, long winded so on with some pics.
what I started with
the first cut
the second cut (crane worked slick)
third cut
this is exactly how it was stock, I will add an inner gusset once I figure out where the cylender will go.
outer gusset/brace just to satisfy me, there were none on it stock.
I just realized that in the 7th pic you can't see the rest of the piece, it's 4" x 1/4" plate that i bent on my homemade press brake.
   / dump trailer build round 2! #3
Nice!
For me, I would have kept it at 30'. That would have made a nice dump :thumbsup:
   / dump trailer build round 2! #4
To heck with the dump, I want to see that homemade press brake!!!!! That is a project of mine that has been on the back burner for about 25 years!!!!!! :laughing: mostly because I work in sheet metal and if I need something bent I take it to work and bend it! :D
Nice start to you dump though. I built a 6.5' x 16' tandem trailer a few years ago from an 18' camper. I paid $75 for the camper and stripped it down and got $110 out of the scrap steel and aluminum! Keep the pics comming! Is this to be towed on the road or strictly an off road dump?
   / dump trailer build round 2! #6
Nice!
Probably be over 10k though...
Have you guys ever had one inspected/certified for over 3,000lbs ?(a trailer)
I had a home made car trailer, and it seemed light a nightmare to try and get it registered for over 3,000 lbs so I sold it. Needed like proof of axle capacities, proper shackles/springs, brakes, tongue with weight distribution proper.
-- Joe
10" drums so I will assume they are 3500# axles. I don't plan on loading it all that heavy, mostly for roof tear offs and construction debris, a little firewood now and then. Gravel and such I will leave to the dumptrucks.
I had built an ATV trailer a few years back from an old popup camper frame (my brother backed over it with his big excavator...LOL) anyway, I had no trouble getting it registered as homemade, just had to weigh it and take the weigh slip and size to DMV, was a piece of cake here in NY.
I also registered a few in VT as homemade (when I lived there) and never had any problems.
I picked up some 3" x 1 3/8" C-channel today, three 20' sticks. Nice to have some new material to work with for a change! LOL
I don't want to start the dump frame unitl I know where the piston is going to be mounted (it will be easier to have that end in before the dump bed as I have no way to lift it once I build it in place).
I could always get my neighbor with his tractor and fel to lend me a hand, he restores old trucks and gas pumps.
I have a question, lol, what are your thoughts on putting some sort of spacers between the frame and dump bed frame? I was thinking maybe some UHMW or even lexan. Or should I just let the dump bed frame sit right on the frame?
I'm making progress, I will take some more pics once I clean up the garage a little...lol
IT LIVES!!
I picked up a 4" x 24" x 2" cylinder yesterday afternoon and went to work this morning on fitting up the rest of the subframe so I could get the cyl. in. I took the poweerpack motor apart and re-installed the brushes and hitched it all up and low and behold it lifts! I had to do some experimenting with the solonoids to get it to come down though...lol.
   / dump trailer build round 2! #10
I like your new trailer. Glad you got it dumping.
Sorry I couldn't resist mentioning this due the picture below.
Stopped at a stoplight and pulls up next to davedj1. Sir? (Scratches head) You seemed to have lost part of your trailer back there. :confused2:
It must have broke in half. :laughing:
Chad
(1) 16ft Tarter Gate (A48837)
(1) 16ft Tarter...
(3) Rolls of 5inch Fire Hose (A48837)
(3) Rolls of 5inch...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
2017 Dodge RAM 1500 4WD Pickup Truck (A50860)
2017 Dodge RAM...
Hotpoint DBL1550BALAD Dryer (A50860)
Hotpoint...
