Dump bed goes up but won't come down
   / Dump bed goes up but won't come down #1
Spudgunner
Central Idaho Mtns
Kubota BX-23 & Toolcat 5600 D
I've come across a strange bug. My in-cab dump bed valve won't budge after I raise the dump bed to maximum height. I can fix the problem by manually bleeding hyd fluid from one of the two bed lift cylinders. This relief of pressure in that circuit allows the operator to then lower the bed. The bed works fine as long as I don't raise it to absolute max. height.
My "if it hurts to poke yourself in the eye, then don't poke yourself in the eye" approach of not raising the dump bed to max. height works fine, but I'm sorta curious what may be the problem here. Any ideas?
   / Dump bed goes up but won't come down #2
Seems to me that has happened with mine before. Don't recall if I was on a slope but as I recall I held the switch and started moving the TC and it came down.
dsb
   / Dump bed goes up but won't come down #3
Try getting the front of the truck downhill and see if that helps. Maybe go forward downhill and stop fast.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
UNUSED 48 in. Adjustable Pipe Wrench (A50860)
UNUSED 48 in...
2004 Range Rover HSE SUV (A48082)
2004 Range Rover...
2012 Buick Enclave Premium SUV (A50860)
2012 Buick Enclave...
BBQ PIT (A50860)
BBQ PIT (A50860)
