Dump angle
   / Dump angle #1
Yardscaper
Bronze Member
St. Louis, MO
Polaris ASL 300, 1959 Economy Tractor
I was just curious if anyone has ever messed with making one of these machines, particularly the bucket loader 2400 series, achieve a steeper dump angle. This would make the machine a lot more productive for loading trucks, especially one with high sides. I am planning on toying with this aspect of it this winter. Any insight would be helpful.
   / Dump angle #2
My understanding is that for those who need to load trucks, the 4 in 1 offers a good solution - you don't need to 'tilt' to dump - just open the jaws.
-Rob /forums/images/graemlins/grin.gif
   / Dump angle #3
I thought about building a portable ramp.
   / Dump angle #4
my fix to that was to cut out a back in loading area thats about 10'' lower than the drive way that way ill have lots of clearance and can fill it in with gravel and have a place for my sons old beater /oil leaker plus it gave me a nice excuse to use the bucket for practice on the lil green machine /forums/images/graemlins/wink.gif
   / Dump angle #5
On my 1445, my tilt arm has two positions that can be used, probably for different attachments. A cheap solution would be to make a special tilt arm for your application. It could be as simple as a 3/4x2 inx30 in. Bore 3 or four holes that might fit your situation.
   / Dump angle
This may work on the smaller machines, but I am not sure how that would work for a bucketloader. The bar is a cylinder shape that has a set position and is attached using ball joints. But this may be a viable option. I may try to experiment with that suggestion. My 1425 had a bar that was desgned with extra holes.
Thanks for all of the suggestions so far.
   / Dump angle #7
Yardscaper,
I've always wondered if I could replace the dump connecting arm on my 422 with an adjustable 3 point hitch top link with the appropriate size ends on it. I could then lengthen it to get a steeper dump angle on the bucket, and shorten it for other attachments. Someday I'll get around to it...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
Big Dog C-146 Zero Turn Mower (A50860)
Big Dog C-146 Zero...
2006 Honda CR-V LX SUV (A48082)
2006 Honda CR-V LX...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
