Tires Dumb on the Farm
   / Dumb on the Farm #1
Dumb on the farm
I have an L 3130 HST 4 wheel drive,I need front tires and was wondering what does rolling circumferance mean? I have 10x16.5 NHS on it.Rim size 16.5x 8.25.I want to buy a tire mounted on a 16.5x8.3 rim, how much difference is this? I just need a 10 x 16.5 tire to fit and not mess up anything.One other question I have 420/70 x24 on the rear,is this close to 17.5x24?
   / Dumb on the Farm #2
The rolling circumference is the inflated diameter
of the tire at the recommended tire pressure.
You also need to under stand the rolling radius
of a tire which is half of the rolling diameter.
The width of a rim allows some additonal
tire tread width sizes, BUUUUUT
if you buy a wider tread tire it may affect
the steering arc and in effect reduce it,
rub on the axle as it is too wide and
eventually blow the tire.
Maybe a better fit would be a turf diamond tread
tire of that size for you as there will be no large
tread lugs further exposed in a tight turning radius.
part two -This is the metric equivalent of the tire size
also molded into the tire sidewall.
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
2022 Chevrolet Tahoe FL SUV (A50324)
2022 Chevrolet...
Club Car Carryall 1 Utility Cart (A51691)
Club Car Carryall...
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
UNUSED FUTURE SKID STEER PILE HAMMER (A51244)
UNUSED FUTURE SKID...
