dumb Kubota BX25 question
/ dumb Kubota BX25 question #1
bbaley
Yacolt, WA
Kubota BX25D
Hi - I have a BX25 and no Mid-Mount Mower -
my question is - how can I keep the linkage/arms all the way up all of the time ?
It was not obvious looking under there how to physically lock them in the highest/up position.
Since I never have a mower deck on I was wanting to keep those up and out of the way
/ dumb Kubota BX25 question #2
If you put them all the way up, they should stay there. Mine do at any rate. All winter long they stay all the way up anyway. Do yours slip down?
Not a dumb question, just never seen them fall unless you tell them to fall!
George
/ dumb Kubota BX25 question #3
The three point arms and the underneath linkage are connected. If you make sure the wheel that allows flow is open, with the tractor running, pull up on the three point linkage lifter. As you're holding it up, spin the mower height adjustment to Top. It has a tab that will lock it in place. After that, the lower linkage will stay up and you can use the rear three point, normally. You can also turn off the hydraulic flow, to the lower/rear linkages, which will help. Other than the mower height adjustment, I don't think there is any other great way.
Every once in a while, turn the flow knob, if left a long time, they can get stuck.
/ dumb Kubota BX25 question #5
did you set the dial knob to top position? if you cant get to that point - lift the 3 point lever till you can turn that knob to the words top that is by your left feet sitting. once you get it in top - leave it there unless you plan to use snowblower or mmm.
IGERSOLL-RAND AIR COMPRESOR (A60736)
IGERSOLL-RAND AIR...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Trimble Guidance System (A60462)
Trimble Guidance...
Volvo EC220EL (A60462)
Rough Country Bed Cover (A60463)
Rough Country Bed...
