Dufas Moment...
   / Dufas Moment... #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Wife & I replaced the handrail on an elevated deck off a back bedroom. No great shakes. Got the parts, measured, stained, cut....now getting ready to install and she notices one of the stiles (?) that hold all of this...was loose. Looking closer, seems when this was refinished several years ago, someone or something had pulled the bottom two nails out of where it was attached.
I was going to simply screw it back in when I realized these nails are the reason why it won't go flush. I bounce down two flights of stairs to get my oscillating saw but alas, no metal cutting blades. Not to fear, I pull out my sawzall which I know DOES have some metal cutting blades, but it's bigger and a bit tighter to fit in the 1 1/2" space I had.
Carry it back up, sit on deck to assess things and start to attach the blade. Can't quite reach it as it's retracted.... no problem, I GENTLY pull trigger to get it to move out....and it's 100% dead. Zero, nothing.
Memories of once having a gallon jug of muratic acid dripping in the garage (thankfully, right above a stainless container which caputured it BUT the fumes still caused us issues)
I'm wondering if this has been eaten away inside. No worries, if so, I can take apart to clean/fix. It has the slider on top to go into oscillating mode or not.... it WOULD NOT budge....adding to my fears that the guts were eaten away when that acid got loose.
I then had a slap my forehead moment......
Yep..... though cord was plugged into wall..... the other end was not plugged into the saw itself. I didn't attach it as I was sitting with saw on my lap.
yeesh.
(nails now cut and stile is firmly attached)
I figure if I can't fess up to being a dufas, then my wife will beat me to it and announce it!!
(y)
   / Dufas Moment... #3
I have a 3000 W Honda generator. I use it out on the property to run my corded tools. Battery powered tools seem to die prior to project completion.
So I have a project. Way out in the NW meadow. Load the generator, Hole Hog drill, drill bits, gloves, toilet paper, water - onto the tractor.
Get all the way out there - where in the @#$% is the extension cord.
By the time I get back from getting the extension cord - it's starting to get hot - I'm pissed - this project will now be a sweaty endeavor.
I won't make this mistake again. However - I fear there are others - just waiting in the wings.
   / Dufas Moment...
I'll just refer to you as "BD" or, Brother Dufas!
(y)
   / Dufas Moment... #5
I once needed an extension chord to power the fridge with my generator during a power outage. I walked out to my shop, hit the light switch without thinking, walked over grabbed the extension chord when I realized the lights were on. I guess I don’t need this extension chord anymore huh.
   / Dufas Moment... #6
I can't count the amount of time I unplug the skill saw to plug the grinder but I simply re-plug the skill saw, then I wonder why the grinder is not working :rolleyes: ... or going around looking for my flat head screw driver while holding it in my hands :rolleyes: .... or I am looking for my pencil, can't find it, so I go get a other one, make my mark and I go to put it on my ear and there is already a pencil there:cautious:....
Our horse fence is electric but it is currently powered by the camper generator (for now) they needed to get zap once or twice so they respect the fence, now that's done we don't need it on but I will still transfer it to the grid once I built the fence close enough to my parents house. I was in the camper in the morning and I start the generator to make my coffee, since I was out I go check the horse water tub level and it was a bit low so I went through the slinky gate (which is electrify as well but usually the power is not on) to fill it, as I go through the gate I have this electric sensation in my hand, balls and right foot ( left foot was in the air), in the heat of the moment I was thinking did I just pull a muscle or got a hernia?? What was that, how can it went from my hand and balls to the feet why the hand ?? then it occur to me the generator is running! so the fence is live, duhh... but it took me a second .... Ok Yes it was early in the morning and I had a few beers the nigh before ...
I hope these 4 makes you feel better... the worse of all is there is nobody to get mad at other then yourself.
   / Dufas Moment...
I will simply relate that a plasma cutter will not cut worth a damn if the ground cable isn't clamped to the piece you're trying to cut.
what do they say...
"pics or it DID happen!"
   / Dufas Moment... #9
Even in Australia!
   / Dufas Moment... #10
Boy, I wouldn't know which one to go first with I've had soooo many of those.
When I was 19 a guy (he was in his 30s) asked me to haul a fridge to the other side of town. He went with me.
No need to strap it down just go slow. Didn't even get off the first Street, never went above 30 mph, KABLAM! Fridge blew over in back of truck.
Never worked again.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
1995 Case IH 2144 Combine (A50514)
1995 Case IH 2144...
2014 Ford Explorer XLT SUV (A50324)
2014 Ford Explorer...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
