Duckweed treatmwent for pond?
   / Duckweed treatmwent for pond? #1
Tollster
Veteran Member
Benton, Pennsylvania
Kubota, BX23
Has anyone successfully treated it? I have a small pond and have a hard time figuring surface acreage.
After some research I found Diquat Dibromide to be highly successful, but there are strong safety precautions that should be adhered to, per the MSDS.
Has anyone used this stuff?
The MSDS suggest a paper suit and particulate filter. I have a half mask 3M, I use for painting, do ya'll think this will suffice, with safety glasses?
I have tried other stuff, such as copper sulfate and an aquatic herbicide used in farm ponds with restricted water use for the first two weeks. None of it could touch it and it seems to only grow worse each year.
   / Duckweed treatmwent for pond? #2
Can you post some pics of your pond?
You could contact your local ag dept of you state university to assist you in deciding how to tackle the problem.
   / Duckweed treatmwent for pond? #3
Duckweed is a tough one. Copper sulfate has never been labeled for it, and as you found out will not touch it. Not sure what is still on the market, but Reward and a formulation of Sonar were labeled for duckweed. Be sure to follow the application times and rates closely to get a good kill. Surface acreage is length times width. An acre is 43,560 square feet. Good luck.
   / Duckweed treatmwent for pond? #4
Try Karmex (diuron) herbicide. Click on the link for a description. It's a dry granule and I just sprinkle it around the edges.
Note: it is a total kill herbicide. It gets ALL of the vegetation, but won't hurt your fish or livestock.
   / Duckweed treatmwent for pond? #5
You can sell duckweed in the aquarium and tropical fish circles, as long as not to certain states. With more moderate climates, it becomes more invasive. Also most carp love to eat it, so could control it that way.
   / Duckweed treatmwent for pond? #6
I hope this is old news: The duckweek is problem because the pond has high nutrient levels. Duckweed is one of natures tools to deal with the nitrates etc.
How many gallons is the pond ?
   / Duckweed treatmwent for pond? #7
Duckweed is tough but I had Watermeal which is worse. A combination of Sonar and Reward were the solution and it worked. 1/2 acre pond.
Sonar works when the plants bob below the surface and get in contact. I sprayed Reward manually. When the plants blow to the corner of the pond, I would spray them. Sometimes infrequently, other times multiple days in a row. Eventually the plants disappeared. It takes time and attention but eventually works. Good luck
   / Duckweed treatmwent for pond? #8
Duckweed is the fastest growing plant there is.
But it's bot as bad as it looks. Some cultures eat it and I've read that it makes good chicken feed, up to 20% protein. It cleans the water, doesn't take oxygen from the water and will keep the water cooler cutting down on evaporation and oxygen depletion. My pond water is much clearer since the duckweed invasion and it provides a significant protein source for the fauna that habituates the pond.
I've decided to forgo the herbicides for now.
   / Duckweed treatmwent for pond? #9
try sonar*a.s.
   / Duckweed treatmwent for pond? #10
I've been using Sonar from SePRO (fluridone) to control Hydrilla in my 4 acre pond. Sonar is also supposed to be very effective for duckweed. The liquid form would be very easy to use. Just pour the proper amount in the pond and it will spread throughout the water. It's crazy expensive, but might not be too bad if your pond is small.
See this page from SePRO for more info:
https://www.lakelawnandpond.com/DuckweedBasics.aspx
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2009 John Deere 1810E Scraper Pan (A53342)
2009 John Deere...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
