Ducks!
/ Ducks! #1
dooleysm
Platinum Member
Southern Indiana
All this chicken talk has reminded me of a duck question I have.
We had various ducks around 2 summers ago, but they all ended up disappearing. In all but one case, the whole flock disappeared (3-5 each time). That time 1 survived, but was lost in the next round of disappearances. I assume dogs, as there are a number of them roaming around at any one time. I never found any piles of feathers, but I didn't look too hard either. I figured if it was a hawk they would have disappeared one at a time. They weren't tame enough to be easy to catch, so I doubt if anyone stole them.
We just had them around as decorations more than anything. I did eat one, but it was too much work to pluck and not worth the effort. They seemed to do a good job of cleaning up the pond though, keeping weeds down and so forth. Plus they were fun.
All that to say we want to try again. To that end we've come up with an idea for a 'duckhouse'. I thought I could make something that would start on land and extend out over the pond several feet. The idea would be to hopefully provide the ducks with a place to sleep that would be safe from air and ground assault. I think I could build something fairly cheap from material I have laying around. If it worked for year or so I would think about building something a bit nicer. If not, no big loss.
Any thoughts on whether this will work? Will the ducks use it? Any better ideas? Should I even bother?
/ Ducks! #2
If there's a walkway over the water, it's not safe from land assualt.
We have ducks that stop off anually. Last year a nest appeared on the bank of our pond (0.2acres) and had 7 eggs in it.... After a hail storm I went out to check on them, and they were all gone. No shell, no mush... nothing.
It was then that we noticed a family/lead of foxes in the area... and they're always partial to some eggs.
This year, I'll be making a floating island for them to nest on with fresh willow sticks poking though the base that reach the water to give woven/natural cover. Ducks don't need walk-ways to get to islands.... So long as you're not planning on collecting eggs, then it shouldn't be a problem.
Anchor an artificial island with a big stone or string of bricks on a line... It make the whole construction easier... A lump of foam (old car fender/bumper) and a pallet will get you started.
/ Ducks! #3
How big and deep is your pond? I have had ducks for a few years now and have only lost ones that nest a ways from the pond. Normally they all just head to the center of the pond and nothing can get to them easily. My pond is about 65ft x 85ft and 13 ft deep.
Eggs and ducklings disappear on a regular basis, which is fine with me as it keeps the numbers down. Lots of ducks = lots of poop on the lawn. I suspect skunks or coons as that is what we mostly have around here. I keep meaning to pick up a game cam and see what is roaming around at night.
I had considered the floating island idea but it turned out to not be necessary.
/ Ducks! #4
I have a small pond in back of the house, aprox 1/4 acre in size with an island aprox centered in it. I've built & put up 6 Wood Duck houses over the years & the wife & I enjoy watching the woodies preform their Spring rituals. All 6 houses are used, 1 year we had a pair of Hooded Mergansers take over one of the houses. I put out some corn for the ducks & whatever else stops in during their migration. The best part is they come & go when they want & I don't have to care for them! They are interesting to watch and they are a sign of Spring when they arrive!
/ Ducks!
My pond is about a half acre and 10+ feet deep in the middle. It generally freezes over for a week or two per year.
After re-reading my original message I think it wasn't clear what I was intending to build. I'm thinking of small pole barn-like structure, maybe 2' wide and 6' long. The house would have a couple feet on land and then extend out over the water. I would partially bury the part on land to keep critters from burrowing under. The part extending out into the water I guess would have to be partially submerged.
My thought was that the interior of the house would only be accessable through the water. I hoped that the ducks would swim in there and nest for the night and that no predator would be smart enough and determined enough to swim out and into the structure.
/ Ducks! #6
Shawn, while hawks, owls, dogs, coyotes, and foxes are the primary suspects in your "Case of the Disappearing Ducks" mystery, I wonder if you have any really big turtles in your pond? I know turtles can take baby ducks, but don't know if they are a problem for grown ducks or not.
/ Ducks! #7
Believe it or not, large bass are VERY dangerous to small ducklings. I would have never thought this until one day on my FIL's pond, I caught about a 5lb bass that had a small duckling halfway down it's gullet. We watched about 50 newly hatched ducklings disappear one summer.
/ Ducks! #8
when i was a teenager, we used to spend weeks fishing at my uncle's pond......many times the ducks would start to cross the pond sunddenly to disappear, only to pop up on the other side of the pond frantic and trying to escape.....at first we thought we thought they were just being ducks and going under.......after a while, we figured out it must have bee turtles....there were some HUGE turtles in that pond...snappers....
/ Ducks!
Except for the first 5, they were all full grown ducks. The first 5 were big enough that no bass in my pond could eat them.
I don't know about turtles, I'm sure there are snappers in there. I sure hope there aren't any big enough to take down an adult duck. Even if there are, what are the chances they could take down 3 ducks in one night?
/ Ducks! #10
They are not like chickens, they don't go and 'roost' every night. I am not sure they would use any type of shelter unless you feed/herd them in there every night and lock them up.
/ Ducks! #11
Snapping turtles have taken full grown ducks from my pond. I don't think turtles have to be huge to grab a duck from underneath and pull it down.
/ Ducks! #12
put you some turtle jugs out and you find out:thumbsup:
i've seen turtles pull the jug under water for what seemed like a long time and then pop up somewhere else......put the lid on a 1 gallon jug and go push it down in some water...hard to do........turtles must be crazy strong and if you are "feeding" them, they probably are good sized
/ Ducks!
Thought I'd give an update on my duck house project. I got around to it last weekend. I ended up using all scrap material I had on hand. The only things I bought were 3 hinges for the lid, and a handle for the hinged portion of the lid. The house is 3'x9' and about 2' tall. The roof and 3 sides are covered in metal. One 3' side is open and there's no floor. I dug an area out in one corner of the pond and about half the house sits on land and the other half sticks out into the water. I've got 2 2x6 posts nailed to the end over the water, going down and resting on the bottom. It was a quick job and it's not the prettiest thing in the world.
I took the ducks' food away Friday evening and built most of the house then. I finished it Saturday morning and we moved it down to the pond and got it in place. I put a bowl of food in the house and moved the ducks down there. They were hesitant to stay in the house at first, but we stayed on the bank and kept them from coming up on land anywhere but in the house. They now spend most of their time in the house. They seem to be doing great. They have taken to the water and seem to be gorging on all the algae. I've spent all spring fighting that stuff with chemicals and the ducks have almost totally eliminated it in just a couple days. I wish I had known this sooner.
So far, so good. Keeping my fingers crossed!
/ Ducks! #15
That's a beautiful looking pond! I saved it under my "Pond Ideas" folder. Do you have any more to share?
That pond I was talking about would get little itty bitty looking lilly pads. I always heard it called duck weed. It would take over the pond QUICKLY! We would take rakes and pull it up on the bank. We would, of course, would miss some. When we came back the next day and over the next week, we lost all ground we had gained. My aunt and uncle got some ducks and they would tear through it in a couple of days and keep it clean. When I watched them eat it, it didn't seem like they swallowed it....almost like they chewed on it and then spit it back out.....but I could be wrong.
Thanks for giving us an update.....
/ Ducks!
My pro tip for ponds is to find someone who knows what they're doing. I thought I had, but last minute they sent out a different dude to dig the pond. My dam leaks. Knowledgable people I've talked to say that my soil was too rocky to build a proper dam.
It looks nice when it's full, and it stayed full last summer, but we had an unusually wet summer. We'll see how it goes this summer.
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
John Deere 4044M (A60462)
John Deere 4044M...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
