Tires Dual Wheels on the NX Series Kioti
   / Dual Wheels on the NX Series Kioti #1
Bigfish50
Bronze Member
Gainesboro, TN
Kioti NX5010 and 54 Massey Ferguson TO35
In my quest to make things more stable on hills was looking to see if anyone has put dual rear wheels on their NX Series tractor? Have already turned the wheels around and added fluid to the tires on mine and was looking to see if anyone had taken this additional step.
   / Dual Wheels on the NX Series Kioti #3
If your axles, rims, and wheel bearings will take the stress then I don't see any reason why you can't run band type duals.
Thanks for the inputs guys. DieselBound those are some really large tires on that NX! Anyhow, to oldnslo's point I don't know if axles etc would take the additional stress of having more rubber on the ground so was looking to see if anyone else had taken this step. Not sure I'm comfortable being the pioneer on that front just yet. For the time being I'll see how much mileage I get from filling my tires.
   / Dual Wheels on the NX Series Kioti #5
When you dual it up, be sure and have your dealer order in a new axle, and buy the tech manual too, so you know how to install it!
BECAUSE, unless you are on fairly flat level ground, you are probably going to need it!
SR
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
JOHN DEERE MAX EMERGE 2 (6) ROW PLANTER (A51243)
JOHN DEERE MAX...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
