dual wheel setup
   / dual wheel setup #1
ritchieb
Bronze Member
near Parkersburg, WV
Yanmar 1610D/Kubota B2620
Has anyone put dual rear tire/wheel set-ups on their Yanmars? If so did you use a spacer with bolts and holes mating with the original hub/rim pattern or did you use a j-bolt type setup and pull the tire/rim combo tight against one another? Any pro or con thoughts on this? Thought this might be a way to help stabilize these things a bit more on steep ground.
   / dual wheel setup #2
I got a YM2500 one time that had factory spacers and duals. They were spools that had bolt holes on one side and threaded holes on the other.
   / dual wheel setup #3
I just got my 1500D this week and that is one of the first things that I thought about right away. I was thinking that it might add a little less loading and digging in as the single skinny tires sure tear up everything I run over. But I was also thinking that it might assist with stability. I am scared to death on this thing. I can't find anything anywhere that tells me max roll angle and I don't really wanna find out for myself.
Just wondering what your desired effect is by doubling the wheels?
   / dual wheel setup #4
Here's an old post that describes the dually spools in the Optional Parts chapter of the (American) Yanmar manual.
The post following shows some that an owner had made for him, and then subsequent posts discuss stress. Some excellent design engineers participated in that thread.
Here's the picture of the factory spools, in the parts manual:
   / dual wheel setup #5
Having the spool fabbed up is going to be the only complicated part. Although, it's a pretty simple piece.
I assume they would start with a piece of round stock that was close to the OD of the portion where wheels bolt on, and then turn down the center section?
Or make the end plates and weld them on to a piece of stock the correct OD for the center section? I guess as long as you got it properly centered, that would be ok. May actually make it almost a DIY project for those of us that don't have a lathe but can weld.
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
EZGO (A50324)
EZGO (A50324)
1275 (A50490)
1275 (A50490)
RIDGID DIE HEADS (A53843)
RIDGID DIE HEADS...
