Dual Voltage Welder
   / Dual Voltage Welder #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Does a dual voltage welder automaticly detect if its plugged into 110 or 220?
   / Dual Voltage Welder #2
   / Dual Voltage Welder #3
I was able to attend the FABTECH show yesterday in Chicago. Every kind of welder or welding equipment as well as anything that you could imagine that has anything to do with fabricating, cutting, or robotics, along with consumables and safety equipment was represented and displayed. My main purpose was to look at welders, particularly dual voltage mig welders. I looked mainly at the Lincoln and the Miller. The Miller has a changeable plug and the unit decides the input voltage based on the plug. The Lincoln requires you to change the actual cord from a 110-120 to a 220. That is how the machines know their input voltage. I would think that with the Miller the cord only supplies one side of a 220 circuit to the machine when you change the plug from 220 to 110 since the cord is the same, while the Lincoln's input is based on which cord is plugged into the machine. I did not see any other dual voltage machines, but there were a lot of gray market representatives and I did not vist all of them. McCormick place is a pretty big place and my time was limited.
ESAB also had some great equipment, but I think that their equipment is out of my price range and they do not have a dual voltage machine.
The higher end mig machines ( over $1000, 220 input only) are pretty much goof proof and do all the thinking for you.
I hope this helps.
I hope this helps.
I read about that show today, appears it was a great display... good for you that you got to attend.
I probably don't use a welder over 50hrs a year so i'm looking at this one...thats why I posted the question. From what I gather this unit detects the voltage by the plug and then I'd build a pig tail.
   / Dual Voltage Welder #5
Take a look at the EverLast PA140ST welder, it's 110/220 volts.
Very nice little portable unit. I set mine up to run on 220, some people use 110.
   / Dual Voltage Welder #6
I think auto switching dual power is just one more thing to go wrong. What if you have been using it on 110v and then plug it in to 220 and it doesn't switch.
Bill
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2019 Nissan Frontier Pickup Truck (A51692)
2019 Nissan...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2121 (A51244)
2121 (A51244)
2008 Honda Pilot SUV (A53117)
2008 Honda Pilot...
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
