Dual front wheels on 425?
   / Dual front wheels on 425? #1
Eaglepb
Alum Creek,WV
2009 2816 Mahindra Gear Drive w/FEL 47 Ford 2N
I have mostly hilly ground here in WV. Was wondering if anyone has used dual wheels on front of 425 for better stability. Thanks..BB
   / Dual front wheels on 425? #2
There's been some discussion on this. From what everyone is saying, the factory doesn't recomend dual wheels because of the possibility of overstressing the wheel motors if you would get up on the edges of the outside wheels. Some folks think it is your machine and you should do what you want with it.
Personally, if my slopes were that steep, I'd start looking at a different machine, as the Kohler is only rated for 20 or maybe 25 degrees due to its oiling system. Prolonged use at greater angles could cause engine damage.
I've seen pictures of early Power Tracs that were similar in size to the current 400 series. They had dual wheels, but the wheels were much narrower than the current wheels.
Hi Moss: Thanks for your info /forums/images/graemlins/laugh.gif...My hills would not be over 25 and I really am liking the PT concept. How is the new Robin Engine rated for slopes? Tks..WV
Electric Concrete Mixer - (A51573)
Electric Concrete...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2019 FORD F-350 (A52472)
2019 FORD F-350...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
