Dougster
Veteran Member
Has anyone out there converted a dual-axle equipment trailer into a tri-axle equipment trailer? I am thinking of doing that in lieu of a 15-inch to 16-inch tire upgrade on my 10K, 20-foot equipment trailer. Here's what it looks like right now more or less (except 4' longer):
As most of you know by now, I found religion after a twin tire failure incident on the highway and am in the process of upgrading my 10K dump trailer tires to ST235/80R16LRE tires capable of handling a 14K load. I planned to do the same on my 10K equipment trailer, but then I got to thinking about those mere 5,200 lb axles on the equipment trailer (vs. 6K on the dump) and how adding a third non-braking, 5,200 lb axle would achieve the same load and tire blowout "safety factor" I sought at roughly the same net cost since I already have two leftover 15" wheels and tires to use from the dump trailer. If placed behind the current axles, it would also help with my driveway-to-street dovetail dragging problem as well.
Fender replacement is dirt cheap... and together with the new axle and springs it would still be cheaper than four new 16-inch LRE tires and wheels. Plus I get a 50% safety factor... essentially one full axle's worth of redundancy... for less net money!
Does this make good sense??? Or am I missing something here???
Dougster
Dougster
