Du-al 30228 cylinder
   / Du-al 30228 cylinder #1
Golf man
Ford 1500
Can anyone help me I have an old loader with Du-al30228 hydraulic cylinder that I need to replace. Any help on how to find one. Thanks
   / Du-al 30228 cylinder #2
I think Woods bought Du-Al.
   / Du-al 30228 cylinder #3
Woods did buy Du-Al They no longer make loaders and shut the Souix Falls factory down a few years ago (darned if I can remember when).
What model of loader do you have and why does the cylinder need replaced? If it is leaking then you could just have it resealed. The seal kit for the 30228 cylinder is 30236-1.
If you need a new cylinder then you will need to measure it and provide dimensions as the cylinder is no longer available from Woods.
Thank you for the help. I will try and rebuild it. There might be a slit crack in the casing but think I can weld it. Thanks for the parts #
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53472)
2023 New Holland...
JOHN DEERE 7210R LOT IDENTIFIER 256 (A53084)
JOHN DEERE 7210R...
LMC LOT IDENTIFIER 262 (A53084)
LMC LOT IDENTIFIER...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 8 (A53084)
2024 JOHN DEERE 8R...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
