Dry Rot
   / Dry Rot #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
In 2002 I bought a new Massey 231s. The machine lives in the barn and has GoodYear tires all around. I noticed the other day that the front tires are beginning to dry rot/crack on the side walls. What's the deal? Are new tires in my near future or should I not worry about it.
   / Dry Rot #2
With those tires being only 9 yrs old, I wouldn't worry about it. Sounds like it's just the typical cracking you get on most any tire as it ages. If they continue to deteriorate you may eventually need to put tubes in them, unless they already have tubes. Otherwise, considering the price of new tires, run them and get what you can out of the them!!
   / Dry Rot #3
I know of tractors that have tires that were installed back in the 60's. I do not think you have a problem.
   / Dry Rot #4
I have tires on my 1952 Case VAC with plenty of cracks. No worries for me,I have inner tubes. I suppose you could slow down the natural occurrence of cracks with oil or silicon. Baby oil actually works really well and has no side effects.
   / Dry Rot #5
as long as they do not split thru or seperate the bead, run them. even if you have to tube them.
heck.. I've seen farm tires that split and were laced up with twine or bailing wire than a patch put on the inside :)
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
