Dry pet food dispensers ??
   / Dry pet food dispensers ?? #1
countrybumpkin
Elite Member
Kioti, kubota
Been thinking of buying a few of the plastic wall mounted pet food dispensers , just wondering if anyone has come up with a better maybe DIY built ones? Looking to hold about 40-50 lbs of bird, cat, and dog food.
Something like this is what I've been looking at.
   / Dry pet food dispensers ?? #3
We had Two Medal ones from little Giant holds around 50#We had them for years and work great.
   / Dry pet food dispensers ?? #4
I've had one for about 10 years or so for dog food, works well, much better than storing it in totes and such.
Be careful of where you place it. When I first got mine, I just lagged it onto a light pole next to the garage and thought I was good to go. The local raccoons must have found out about it the first night. They'd climb up the backside of the pole, then start feasting. I even put a concrete block on the top, but they'd just push the block off and continue to eat.
I finally lagged it onto the side of the garage (covered in vinyl siding) and they haven't been able to get into it since then.
   / Dry pet food dispensers ?? #5
I use one from these folks. I enclosed the entire gizmo in a heavy wooden box that is coon proof. The food drops out into a bottom tray. I feed two cats this way. The feeder holds about 2 weeks worth of food.
Deal #18A CSF-3XL Cat Feeder w/Stand/Bowl, Chute Cover, ACAT-23 Analog Timer and 24-Cup Hopper - Super-Feed Enterprise
Here is another page that I used for ideas when building my feeder box. I have used it for years this way now.
Automatic Cat Feeders Automated Pet Water Feeder Timers Auto Cat Food Feeders
   / Dry pet food dispensers ?? #6
they work good.
do realize that after about 5ys.. they crack. ( so you buy another and yer cool again.. )
   / Dry pet food dispensers ?? #7
I have a plastic one I have had for 20 yrs or so. Don't use it any more, but it is still on the side of my shed, under cover from the weather. It worked great.
went back and looked at your original post, mine is a feeder, not a dispenser. Mine you fill with food, and the dog pushes in a door in the front and eats from the bottom, more food comes down as they eat.
   / Dry pet food dispensers ?? #8
20ys? dang!
I've been thru 2 sets in my house since 2000, still on the 2nd, but corners are cracked again now!
   / Dry pet food dispensers ?? #9
both of mine are galvanized are as good as new and are 10 years old.
They will be kept on a wall inside a feed room in the barn that we have for cats and dogs, so even the plastic ones sound last for some time. If I can find metal ones for a reasonable price I would go that route. If it wasn't for all the wild critters around here I would consider the auto feeders.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
