I've got a Kioti CK2610 that I use to cut and make hay on about 5 acres. Been making hay for 3 years now using an 80 year old sickle bar, a side delivery rake, and a NH 67 baler. My tractor is only 25 HP but actually does pretty good with this equipment. Lately my sickle bar has been more and more unreliable and has broken down on me the last two cuttings. I got tired of it and found a 2020 model Ibex TS51C drum more for a good deal on FB marketplace.
This mower is rated as needing 20 PTO HP, and is marketed specifically for smaller tractors like mine. I can run it okay but I found it takes quite a bit to get it started. I have to quickly engage and disegage the PTO 4-5 times with the engine at about 1300rpm to keep the engine from stalling while the mower gets up to speed. This is the method recommended by the mower importer that sells them in the US.
Is it hard on my tractor to start the mower this way? I have a foot clutch for the PTO so another option would be to slowly release the clutch, but I'm concerned that could wear the clutch out. I also have the ability to add an extra 10 HP by turning out my fuel screw and removing one shim from my injection pump (IDI engine), but I was trying to wait until my warranty is up in a couple years to do that. Even then I don't think it would have quite enough torque to start this mower at low speed.
