Drop Spindle??
   / Drop Spindle?? #1
gatordog
TX
1980 MF 280, 1979 IH 684
Need help, I just removed the bushings on the spindle housing and installed the new ones (FYI it is a PITA). My questions is, the bushings are too big to let the spindle go in the housing, since the top of the spindle (were the bracket goes to turn the tire) is larger then the bushings. The problem is where the bushings actually go on the shaft, once installed they should be fine. So should I have have the top of the spindle turned down or bore out the bushings??? If I bore out the bushings than I might end up with a loose front end. If I mess up the spindle than they are about 200 new, have not priced used, but the used ones are most likely the same as mine. FYI it looks like this tractor was never greased.
2008 Ford E-350 Cargo Van (A51692)
2008 Ford E-350...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51691)
2007 Ford F-550...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2011 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A51692)
2011 Chevrolet...
Travel Trailer (A51694)
Travel Trailer...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
